跳转到主内容
HP Envy x360 m6 - aq003dx Display Screen Replacement
你所需要的
  1. HP Envy x360 m6 - aq003dx Display Screen  Replacement, Back Panel: 步骤 1 中的图像 1,3 HP Envy x360 m6 - aq003dx Display Screen  Replacement, Back Panel: 步骤 1 中的图像 2,3 HP Envy x360 m6 - aq003dx Display Screen  Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Turn the laptop over and use the plastic opening tool to take off the rubber pads. You only need to take off the two pads at the top for this device.
  2. HP Envy x360 m6 - aq003dx Display Screen  Replacement: 步骤 2 中的图像 1,3 HP Envy x360 m6 - aq003dx Display Screen  Replacement: 步骤 2 中的图像 2,3 HP Envy x360 m6 - aq003dx Display Screen  Replacement: 步骤 2 中的图像 3,3
    • Use the Torx T5 screwdriver to remove the six small screws.
    • Use the Phillips #0 screwdriver to remove the screws under the rubber pads in step 1.
  3. HP Envy x360 m6 - aq003dx Display Screen  Replacement: 步骤 3 中的图像 1,1
    • Go slowly around the edge with the opening tool. The noises you will hear are due to the small joints popping open. Continue this until you have made your way around the entire laptop.
  4. HP Envy x360 m6 - aq003dx Display Screen  Replacement, Battery: 步骤 4 中的图像 1,2 HP Envy x360 m6 - aq003dx Display Screen  Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the six 4mm screws around the battery using a Phillips #0 screwdriver.
  5. HP Envy x360 m6 - aq003dx Display Screen  Replacement: 步骤 5 中的图像 1,1
    • Disconnect the white connector from the battery to the board. (It is recommended to use pliers to remove the cord to avoid touching the board).
    • Once the connector and screws are both removed, lift the battery up and remove it from the laptop.
    • The removal of the connector and the screws can be done in either order.
  6. HP Envy x360 m6 - aq003dx Display Screen  Replacement, Display Screen: 步骤 6 中的图像 1,1
    • Make sure the the back panel is placed back on the computer so none of the internal components are exposed.
    • Open laptop and lay it completely flat.
  7. HP Envy x360 m6 - aq003dx Display Screen  Replacement: 步骤 7 中的图像 1,1
    • Place the suction cup directly on the screen and apply pressure so that the cup is firmly in place.
  8. HP Envy x360 m6 - aq003dx Display Screen  Replacement: 步骤 8 中的图像 1,2 HP Envy x360 m6 - aq003dx Display Screen  Replacement: 步骤 8 中的图像 2,2
    • Take the opening tool and wedge it between the rubber lining around the screen and the back panel and begin to pry it open by lifting up.
  9. HP Envy x360 m6 - aq003dx Display Screen  Replacement: 步骤 9 中的图像 1,1
    • To take the screen out of the back panel, simultaneously pull on the suction cup while creating leverage between the back panel and the rubber lining.
    • Popping sounds are expected.
  10. HP Envy x360 m6 - aq003dx Display Screen  Replacement: 步骤 10 中的图像 1,3 HP Envy x360 m6 - aq003dx Display Screen  Replacement: 步骤 10 中的图像 2,3 HP Envy x360 m6 - aq003dx Display Screen  Replacement: 步骤 10 中的图像 3,3
    • Once the screen is detached from the back panel, direct your attention to the back of the screen where you will remove the tape holding the screen to the bottom panel.
    • Remove the grey tape covering the wires on both sides by slowly pulling back the tape as not to separate the tape from the adhesive.
  11. HP Envy x360 m6 - aq003dx Display Screen  Replacement: 步骤 11 中的图像 1,1
    • Remove the slender black wire that is connected to the bread board by sliding the cable backwards.
    • Pull down on the tape connected to the cable while sliding it out in order to completely detach all screen connections from the back panel.
  12. HP Envy x360 m6 - aq003dx Display Screen  Replacement: 步骤 12 中的图像 1,1
    • Once steps 1-6 are completed, place a hand on the edge of the screen and slowly pull the screen away from the back panel and remove it from the device.
结论
另外一个人完成了本指南。
一条评论
Thank you for the great illustration with pictures and detailed steps! great job!
Bessie - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 29
总计 1,310
