跳转到主内容
HP Envy x360 15m-cn0012dx TrackPad Replacement
你所需要的
  1. HP Envy x360 15m-cn0012dx TrackPad Replacement, TrackPad: 步骤 1 中的图像 1,2 HP Envy x360 15m-cn0012dx TrackPad Replacement, TrackPad: 步骤 1 中的图像 2,2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 2 中的图像 1,3 HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 2 中的图像 2,3 HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 2 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 3 中的图像 1,3 HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 3 中的图像 2,3 HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 3 中的图像 3,3
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 4 中的图像 1,2 HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 4 中的图像 2,2
    • The battery rest above the trackpad and connects to the black port with the gold pins at the bottom right corner of the motherboard.
    • Remove the screws around the perimeter of the battery holding it down with a Phillips #0 screwdriver.
    • Disconnect the battery cable from the motherboard.
    • Remove the battery by lifting it out of the laptop case.
  5. HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 5 中的图像 1,2 HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the four 4mm screws from the metal plate covering the bottom edge of the trackpad.
    • Using a Phillips #0 screwdriver, remove the three 4mm screws from the top edge of the trackpad.
    • Remove the metal plate.
  6. HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 6 中的图像 1,3 HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 6 中的图像 2,3 HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 6 中的图像 3,3
    • Use the iFixit opening tool, lift up the black lock tab of the ZIF connector.
    • Pull out the ribbon cable from the trackpad connector.
  7. HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 7 中的图像 1,2 HP Envy x360 15m-cn0012dx TrackPad Replacement: 步骤 7 中的图像 2,2
    • Remove the trackpad from the device, lifting the bottom edge first.
结论
Grace Daleki
于02/04/20注册
487 声望
创作了3篇指南
团队
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 的会员
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 25
总计 680
