跳转到主内容
HP Envy x360 15m-cn0012dx Hard Drive Replacement
你所需要的
  1. HP Envy x360 15m-cn0012dx Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 HP Envy x360 15m-cn0012dx Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx Hard Drive Replacement: 步骤 2 中的图像 1,3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: 步骤 2 中的图像 2,3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx Hard Drive Replacement: 步骤 3 中的图像 1,3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: 步骤 3 中的图像 2,3 HP Envy x360 15m-cn0012dx Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx Hard Drive Replacement: 步骤 4 中的图像 1,2 HP Envy x360 15m-cn0012dx Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove one screw from the bottom left corner of the laptop.
    • Use the iFixit opening tool to lift the latch and detach the connector to the motherboard.
    • Remove the hard drive.
    • When replacing the hard drive, you will likely have to transfer the SATA cable and hardware from your old drive to the new one before reinstalling.
结论
另外一个人完成了本指南。
Grace Daleki
于02/04/20注册
487 声望
创作了3篇指南
团队
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 的会员
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 20
过去 30 天: 128
总计 5,129
