跳转到主内容
HP Envy x360 15m-cn0012dx Battery Replacement
你所需要的
  1. HP Envy x360 15m-cn0012dx Battery  Replacement, Battery: 步骤 1 中的图像 1,2 HP Envy x360 15m-cn0012dx Battery  Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx Battery  Replacement: 步骤 2 中的图像 1,3 HP Envy x360 15m-cn0012dx Battery  Replacement: 步骤 2 中的图像 2,3 HP Envy x360 15m-cn0012dx Battery  Replacement: 步骤 2 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx Battery  Replacement: 步骤 3 中的图像 1,3 HP Envy x360 15m-cn0012dx Battery  Replacement: 步骤 3 中的图像 2,3 HP Envy x360 15m-cn0012dx Battery  Replacement: 步骤 3 中的图像 3,3
    • Pry open the seam of the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx Battery  Replacement: 步骤 4 中的图像 1,2 HP Envy x360 15m-cn0012dx Battery  Replacement: 步骤 4 中的图像 2,2
    • The battery rests above the trackpad and connects to the black port with the gold pins at the bottom right corner of the motherboard.
    • Remove the screws around the perimeter of the battery holding it down with a Phillips #0 screwdriver.
    • Disconnect the battery cable from the motherboard.
    • Remove the battery by lifting it out of the laptop case.
结论
7等其他人完成本指南。
团队
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 的会员
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 名成员
创作了5篇指南
4条评论
Great photos and annotations!
One additional tip too for why we should bother pulling the rubber slowly is to also avoid stretching too which will actually change the length of the rubber and have it no longer sit flush on the adhesive like it once did.
Another gotcha too is to note the (+) and (-) terminals on the battery as originally installed. The bad thing about this battery design is that it is symmetric in space which makes it possible to insert it the wrong way! Very dangerous. Take a silver marker and really amplify the terminal pins and note how they are meant to align into the battery slot. Don't get it wrong or you'll short things.
Also worth mentioning since you got the unit open to blow it with compressed air and do any cleaning you can take care of with certain parts easily accessible, eg get that fan cleaned out, etc.
happy fixing folks, good luck!
jxramos - 回复
My front center screw holding the base appears to be a VERY small TORX screw. Any idea what size bit is required?
Brian Morgan - 回复
Mine is too… can’t find anything small enough to take it out
Belinda Kijesky -
Thanks, my laptop is HP ENVY 17-bw000. Uses the same LK03XL battery ... Would be grateful for any tips, guidance. Thanks.
Ramon Tan - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 65
过去 30 天: 236
总计 10,018
