跳转到主内容
HP Envy x360 15m-bq121dx Cooling Fan Replacement
你所需要的
  1. HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: 步骤 1 中的图像 1,2 HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: 步骤 1 中的图像 2,2
    • Be sure the computer is powered off.
    • Remove the rubber strip along the top of the backside of the computer.
    • On the back panel of the device, remove the four (4) 2.5 mm screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq121dx Cooling Fan Replacement: 步骤 2 中的图像 1,3 HP Envy x360 15m-bq121dx Cooling Fan Replacement: 步骤 2 中的图像 2,3 HP Envy x360 15m-bq121dx Cooling Fan Replacement: 步骤 2 中的图像 3,3
    • To remove the back cover, use the spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
    • Be sure to not damage any of the electronics on the inside.
  3. HP Envy x360 15m-bq121dx Cooling Fan Replacement: 步骤 3 中的图像 1,1
    • Use the Philips #0 screwdriver to remove seven 2 mm screws from battery.
  4. HP Envy x360 15m-bq121dx Cooling Fan Replacement: 步骤 4 中的图像 1,1
    • Lift and pull the front of the battery up and out away from the connector to remove.
  5. HP Envy x360 15m-bq121dx Cooling Fan Replacement: 步骤 5 中的图像 1,2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: 步骤 5 中的图像 2,2
    • Using a Philips #0 screwdriver, remove the three 2 mm screws located around the cooling fan as shown in this picture.
    • The fan may have sharp edges so be careful upon removal.
  6. HP Envy x360 15m-bq121dx Cooling Fan Replacement: 步骤 6 中的图像 1,2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the connector clip with the tweezers.
  7. HP Envy x360 15m-bq121dx Cooling Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  8. HP Envy x360 15m-bq121dx Cooling Fan Replacement: 步骤 8 中的图像 1,2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: 步骤 8 中的图像 2,2
    • Remove the cooling fan.
结论
Fabien Perez
于02/13/20注册
157 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 38
总计 1,911
