跳转到主内容
HP Envy x360 15m-bq021dx Wi-Fi Card Replacement
你所需要的
  1. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Battery: 步骤 1 中的图像 1,2 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Battery: 步骤 1 中的图像 2,2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 2 中的图像 1,3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 2 中的图像 2,3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 2 中的图像 3,3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 3 中的图像 1,1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 4 中的图像 1,1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 5 中的图像 1,1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Cooling Fan: 步骤 6 中的图像 1,2 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Cooling Fan: 步骤 6 中的图像 2,2
    • Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
    • Be careful as the fan might be sharp in some places when removing it.
  7. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 7 中的图像 1,2 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 7 中的图像 2,2
    • Remove the connector clip with the tweezers.
  8. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 8 中的图像 1,1
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  9. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 9 中的图像 1,2 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 9 中的图像 2,2
    • Remove the cooling fan.
  10. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Motherboard: 步骤 10 中的图像 1,3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Motherboard: 步骤 10 中的图像 2,3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Motherboard: 步骤 10 中的图像 3,3
    • Using a Phillips #1, remove the seven M2.0x3.2 screws.
    • Undo the six connections using the blue opening tool.
  11. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 11 中的图像 1,3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 11 中的图像 2,3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 11 中的图像 3,3
    • Carefully remove the aux port from the frame of the computer as shown.
  12. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 12 中的图像 1,2 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement: 步骤 12 中的图像 2,2
    • Pull the mother board up and away from frame of the computer.
  13. HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Wi-Fi Card: 步骤 13 中的图像 1,3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Wi-Fi Card: 步骤 13 中的图像 2,3 HP Envy x360 15m-bq021dx Wi-Fi Card  Replacement, Wi-Fi Card: 步骤 13 中的图像 3,3
    • Flip the motherboard over.
    • Pull the Wi-Fi card out from the slot.
    • Remember the orientation the Wi-Fi card is in, as it must be inserted in the same way.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 64
总计 754
