简介
This guide shows how to remove an HP Envy x360 15m-bq021dx touchpad. The touchpad of this model of laptop is fixed beneath the palm rest, so it must be removed from behind. Hardware malfunction may not be the only reason that a touchpad stops working. Check this resource to be sure that the touchpad itself is indeed faulty before removing it.
If you're having trouble clicking with your touchpad, but otherwise it functions normally, check to see if your battery is swollen. Swollen batteries can displace internal components and often disrupt touchpads.
Discharge the battery and unplug your laptop before beginning.
你所需要的
On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
