简介
Hard drives can become damaged or faulty over time, or can just have too little memory or be too slow. follow this guide to replace your hard drive.
你所需要的
On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
Use the tweezers to lift up the retaining flap on the cable connector.
Pull out the ribbon cable from the connector.
另外一个人完成了本指南。
一条评论
Followed guide to remove HDD from 15m-bq121dx model. Steps were identical. Took more force than I expected to remove bottom cover and to get the HDD out.
