跳转到主内容
HP Envy x360 15m-bq021dx Hard Drive Replacement
你所需要的
  1. HP Envy x360 15m-bq021dx Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP Envy x360 15m-bq021dx Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Hard Drive Replacement: 步骤 2 中的图像 1,3 HP Envy x360 15m-bq021dx Hard Drive Replacement: 步骤 2 中的图像 2,3 HP Envy x360 15m-bq021dx Hard Drive Replacement: 步骤 2 中的图像 3,3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to lift up the retaining flap on the cable connector.
    • Pull out the ribbon cable from the connector.
  7. HP Envy x360 15m-bq021dx Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Use the spudger to lift the hard drive from the cutout.
结论
另外一个人完成了本指南。
一条评论
Followed guide to remove HDD from 15m-bq121dx model. Steps were identical. Took more force than I expected to remove bottom cover and to get the HDD out.
Adam Francis - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 14
总计 669
