跳转到主内容
HP Envy x360 15m-bq021dx Battery Replacement
你所需要的
  1. HP Envy x360 15m-bq021dx Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP Envy x360 15m-bq021dx Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Battery Replacement: 步骤 2 中的图像 1,3 HP Envy x360 15m-bq021dx Battery Replacement: 步骤 2 中的图像 2,3 HP Envy x360 15m-bq021dx Battery Replacement: 步骤 2 中的图像 3,3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Battery Replacement: 步骤 3 中的图像 1,1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Battery Replacement: 步骤 4 中的图像 1,1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Battery Replacement: 步骤 5 中的图像 1,1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
结论
另外一个人完成了本指南。
一条评论
Mr. Reihart thank you for this information, could you also say what battery to purchase as a replacement for the 15m -bq.
J r - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 12
过去 30 天: 48
总计 2,292
