跳转到主内容
HP Envy x360 15m-bp112dx Speaker Replacement
你所需要的
  1. HP Envy x360 15m-bp112dx Speaker Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Power off the laptop before starting the disassembly.
    • Start by facing the device upside down with the hinge facing away from you.
    • Remove the seven 1 mm Phillips screws.
  2. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 2 中的图像 1,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 2 中的图像 2,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 2 中的图像 3,3
    • Use an opening tool to pry the back panel by pushing the bottom cover upwards.
    • Place the bottom cover away from the laptop.
  3. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 3 中的图像 1,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 3 中的图像 2,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 3 中的图像 3,3
    • Carefully remove the sata ribbon cable from the hard drive, pulling it out horizontally.
    • To avoid injury, ensure that you disconnect the battery prior to removing any of the cables in the laptop.
  4. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 4 中的图像 1,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 4 中的图像 2,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 4 中的图像 3,3
    • Remove the hard drive by pulling it out vertically.
    • Remove the plastic casing around the hard drive by peeling it back.
  5. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 5 中的图像 1,2 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 5 中的图像 2,2
    • Disconnect the ribbon cable by pulling it away horizontally from the hard drive.
  6. HP Envy x360 15m-bp112dx Speaker Replacement, Fan: 步骤 6 中的图像 1,2 HP Envy x360 15m-bp112dx Speaker Replacement, Fan: 步骤 6 中的图像 2,2
    • Carefully peel back the tape connecting the heat sink to the fan assembly.
    • Loosen the four 1 mm Phillips screws retaining the fan assembly.
    • Remove the three 2 mm Phillips screws.
  7. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 7 中的图像 1,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 7 中的图像 2,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 7 中的图像 3,3
    • Unplug the thin cable connected to the fan, pulling horizontally.
    • Carefully peel back the connected tape.
  8. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 8 中的图像 1,2 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 8 中的图像 2,2
    • Carefully remove the fan assembly by pulling on it upwards.
    • When reassembling, ensure that you clean off and replace the thermal paste on the fan assembly.
  9. HP Envy x360 15m-bp112dx Speaker Replacement, Motherboard: 步骤 9 中的图像 1,3 HP Envy x360 15m-bp112dx Speaker Replacement, Motherboard: 步骤 9 中的图像 2,3 HP Envy x360 15m-bp112dx Speaker Replacement, Motherboard: 步骤 9 中的图像 3,3
    • Remove the two 5 mm Phillips screws from the first speaker.
    • Carefully peel back the tape.
  10. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 10 中的图像 1,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 10 中的图像 2,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 10 中的图像 3,3
    • Open the tab connected to the right speaker cord, prying it with a plastic opening tool upwards.
    • Pull out the speaker cord horizontally.
  11. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 11 中的图像 1,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 11 中的图像 2,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 11 中的图像 3,3
    • Remove the thin cable from the speaker, pulling it out horizontally.
  12. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 12 中的图像 1,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 12 中的图像 2,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 12 中的图像 3,3
    • Remove the right speaker, pulling upward carefully.
    • While pulling on the speaker, unwind the cord around the plastic clips to free the speaker and place it to the side.
  13. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 13 中的图像 1,1
    • Remove the twelve 2.5 mm Phillips screws.
  14. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 14 中的图像 1,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 14 中的图像 2,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 14 中的图像 3,3
    • Unclip the ribbon cable using a plastic opening tool to flip up the black ZIF connector locking flap.
    • Remove the ribbon cable by pulling it out horizontally.
  15. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 15 中的图像 1,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 15 中的图像 2,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 15 中的图像 3,3
    • Unclip the second ribbon cable using a plastic opening tool to flip the black ZIF connector locking flap up.
  16. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 16 中的图像 1,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 16 中的图像 2,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 16 中的图像 3,3
    • Unclip the third ribbon cable using a plastic opening tool to flip up the black ZIF connector locking flap.
  17. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 17 中的图像 1,2 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 17 中的图像 2,2
    • Remove the thin cable carefully by pulling out horizontally in line with its slot.
  18. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 18 中的图像 1,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 18 中的图像 2,3 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 18 中的图像 3,3
    • Unclip the fourth ribbon cable using a plastic opening tool to flip up the black ZIF connector.
  19. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 19 中的图像 1,2 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 19 中的图像 2,2
    • Carefully remove the motherboard by pulling upwards on it.
  20. HP Envy x360 15m-bp112dx Speaker Replacement, Speakers: 步骤 20 中的图像 1,3 HP Envy x360 15m-bp112dx Speaker Replacement, Speakers: 步骤 20 中的图像 2,3 HP Envy x360 15m-bp112dx Speaker Replacement, Speakers: 步骤 20 中的图像 3,3
    • The removal of the right speaker is located in the motherboard guide during steps 1-4.
    • Remove the two 1.5 mm Phillips screws.
    • Carefully peel the tape back.
    • Pull the left speaker cord around the plastic clips.
  21. HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 21 中的图像 1,2 HP Envy x360 15m-bp112dx Speaker Replacement: 步骤 21 中的图像 2,2
    • Carefully remove the left speaker by pulling up vertically.
结论
James Bonnell
于03/20/23注册
331 声望
创作了2篇指南
团队
UMass Dartmouth, Team 6-2, Botvin Spring 2023 UMass Dartmouth, Team 6-2, Botvin Spring 2023 的会员
UMASSD-BOTVIN-S23S6G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 18
总计 141
