简介
Use this guide to replace the screen for the HP Envy x360 15m-bp112dx. A screen may need to be replaced due to cracks or broken parts, flickering on the screen when powered on, and the screen will not emit a display when the laptop is power on.
你所需要的
Start by facing the device upside down with the hinge facing away from you.
Remove the seven 1 mm Phillips screws.
Remove the two 5 mm Phillips screws from the first speaker.
Carefully peel back the tape.
Remove the two 1.5 mm Phillips screws.
Carefully peel the tape back.
Pull the left speaker cord around the plastic clips.
Remove the four 5 mm Phillips screws.
Remove the one 5 mm Phillips screw.
Carefully remove the Wi-Fi card, lifting upwards.
