简介
Use this guide to replace the motherboard for the HP Envy x360 15m-bp112dx. The motherboard is what all components of a laptop are connected to. The motherboard also allows for these components to communicate with each other. It may need to be replaced if error codes appear on a laptop specific to the motherboard, the display is not working, or the blue screen of death appears on the laptop.
你所需要的
Start by facing the device upside down with the hinge facing away from you.
Remove the seven 1 mm Phillips screws.
Remove the two 5 mm Phillips screws from the first speaker.
Carefully peel back the tape.
