跳转到主内容
HP Envy x360 15m-bp112dx Fan Replacement
你所需要的
  1. HP Envy x360 15m-bp112dx Fan Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Power off the laptop before starting the disassembly.
    • Start by facing the device upside down with the hinge facing away from you.
    • Remove the seven 1 mm Phillips screws.
  2. HP Envy x360 15m-bp112dx Fan Replacement: 步骤 2 中的图像 1,3 HP Envy x360 15m-bp112dx Fan Replacement: 步骤 2 中的图像 2,3 HP Envy x360 15m-bp112dx Fan Replacement: 步骤 2 中的图像 3,3
    • Use an opening tool to pry the back panel by pushing the bottom cover upwards.
    • Place the bottom cover away from the laptop.
  3. HP Envy x360 15m-bp112dx Fan Replacement: 步骤 3 中的图像 1,3 HP Envy x360 15m-bp112dx Fan Replacement: 步骤 3 中的图像 2,3 HP Envy x360 15m-bp112dx Fan Replacement: 步骤 3 中的图像 3,3
    • Carefully remove the sata ribbon cable from the hard drive, pulling it out horizontally.
    • To avoid injury, ensure that you disconnect the battery prior to removing any of the cables in the laptop.
  4. HP Envy x360 15m-bp112dx Fan Replacement: 步骤 4 中的图像 1,3 HP Envy x360 15m-bp112dx Fan Replacement: 步骤 4 中的图像 2,3 HP Envy x360 15m-bp112dx Fan Replacement: 步骤 4 中的图像 3,3
    • Remove the hard drive by pulling it out vertically.
    • Remove the plastic casing around the hard drive by peeling it back.
  5. HP Envy x360 15m-bp112dx Fan Replacement: 步骤 5 中的图像 1,2 HP Envy x360 15m-bp112dx Fan Replacement: 步骤 5 中的图像 2,2
    • Disconnect the ribbon cable by pulling it away horizontally from the hard drive.
  6. HP Envy x360 15m-bp112dx Fan Replacement, Fan: 步骤 6 中的图像 1,2 HP Envy x360 15m-bp112dx Fan Replacement, Fan: 步骤 6 中的图像 2,2
    • Carefully peel back the tape connecting the heat sink to the fan assembly.
    • Loosen the four 1 mm Phillips screws retaining the fan assembly.
    • Remove the three 2 mm Phillips screws.
  7. HP Envy x360 15m-bp112dx Fan Replacement: 步骤 7 中的图像 1,3 HP Envy x360 15m-bp112dx Fan Replacement: 步骤 7 中的图像 2,3 HP Envy x360 15m-bp112dx Fan Replacement: 步骤 7 中的图像 3,3
    • Unplug the thin cable connected to the fan, pulling horizontally.
    • Carefully peel back the connected tape.
  8. HP Envy x360 15m-bp112dx Fan Replacement: 步骤 8 中的图像 1,2 HP Envy x360 15m-bp112dx Fan Replacement: 步骤 8 中的图像 2,2
    • Carefully remove the fan assembly by pulling on it upwards.
    • When reassembling, ensure that you clean off and replace the thermal paste on the fan assembly.
结论
Cameron Anderson
于03/20/23注册
289 声望
创作了2篇指南
团队
UMass Dartmouth, Team 6-2, Botvin Spring 2023 UMass Dartmouth, Team 6-2, Botvin Spring 2023 的会员
UMASSD-BOTVIN-S23S6G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 120
