跳转到主内容
HP Envy x360 15m-bp111dx Charging Port Replacement
你所需要的
  1. HP Envy x360 15m-bp111dx Charging Port Replacement, Back Panel: 步骤 1 中的图像 1,2 HP Envy x360 15m-bp111dx Charging Port Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Charging Port Replacement: 步骤 2 中的图像 1,3 HP Envy x360 15m-bp111dx Charging Port Replacement: 步骤 2 中的图像 2,3 HP Envy x360 15m-bp111dx Charging Port Replacement: 步骤 2 中的图像 3,3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: 步骤 3 中的图像 1,3 HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: 步骤 3 中的图像 2,3 HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: 步骤 3 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the two M2x3.1 screws that secure the speaker in place.
    • Lift and move the speaker to the side.
    • Do not pull too hard on the speaker. It is connected by thin wires that run under the motherboard.
  4. HP Envy x360 15m-bp111dx Charging Port Replacement: 步骤 4 中的图像 1,2 HP Envy x360 15m-bp111dx Charging Port Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove remove three M2.5x4 screws that secure the hinge.
  5. HP Envy x360 15m-bp111dx Charging Port Replacement: 步骤 5 中的图像 1,1
    • Use the opening tool to raise the hinge.
    • Then lift the hinge by hand to provide enough clearance to remove the charging port.
    • Be careful when lifting the hinge. The back can be bent and damaged if raised too far.
  6. HP Envy x360 15m-bp111dx Charging Port Replacement: 步骤 6 中的图像 1,2 HP Envy x360 15m-bp111dx Charging Port Replacement: 步骤 6 中的图像 2,2
    • Gently slide the charging port connector out of the port, and lift it above the hinge.
  7. HP Envy x360 15m-bp111dx Charging Port Replacement: 步骤 7 中的图像 1,3 HP Envy x360 15m-bp111dx Charging Port Replacement: 步骤 7 中的图像 2,3 HP Envy x360 15m-bp111dx Charging Port Replacement: 步骤 7 中的图像 3,3
    • Grasp the sliding connector on the motherboard and remove it from the socket.
  8. HP Envy x360 15m-bp111dx Charging Port Replacement: 步骤 8 中的图像 1,1
    • Remove the charging port.
结论
另外一个人完成了本指南。
Tori Luongo
于02/22/22注册
268 声望
创作了2篇指南
团队
Clemson, Team 2-2, Hunter Spring 2022 Clemson, Team 2-2, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S2G2
5 名成员
创作了6篇指南
一条评论
What is a typical charge for a technician to replace the charging port and what should a typical charging port cost?
Robert Ford - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 535
