跳转到主内容
HP Envy x360 15m-bp111dx Battery Replacement
你所需要的
  1. HP Envy x360 15m-bp111dx Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 HP Envy x360 15m-bp111dx Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Battery Replacement: 步骤 2 中的图像 1,3 HP Envy x360 15m-bp111dx Battery Replacement: 步骤 2 中的图像 2,3 HP Envy x360 15m-bp111dx Battery Replacement: 步骤 2 中的图像 3,3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Battery Replacement, Battery: 步骤 3 中的图像 1,2 HP Envy x360 15m-bp111dx Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
  4. HP Envy x360 15m-bp111dx Battery Replacement: 步骤 4 中的图像 1,3 HP Envy x360 15m-bp111dx Battery Replacement: 步骤 4 中的图像 2,3 HP Envy x360 15m-bp111dx Battery Replacement: 步骤 4 中的图像 3,3
    • Carefully lift the battery, and pull it towards you to remove it.
结论
另外一个人完成了本指南。
Tori Luongo
于02/22/22注册
268 声望
创作了2篇指南
团队
Clemson, Team 2-2, Hunter Spring 2022 Clemson, Team 2-2, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S2G2
5 名成员
创作了6篇指南
一条评论
This website has been very helpful but you only show how to remove a battery. You've left out the replace part of the replacement. Would really help. Thanks!
book mite - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 626
