跳转到主内容
HP Envy x360 15-u473cl Touch Screen Replacement
你所需要的
  1. HP Envy x360 15-u473cl Touch Screen Replacement, Touch Screen: 步骤 1 中的图像 1,2 HP Envy x360 15-u473cl Touch Screen Replacement, Touch Screen: 步骤 1 中的图像 2,2
    • Remove the two anti-tamper covers from the bottom corners of the screen using the spudger which will reveal two screws.
    • Remove the two 3mm screws using the J00 Phillips screwdriver.
  2. HP Envy x360 15-u473cl Touch Screen Replacement: 步骤 2 中的图像 1,1
    • Move the plastic opening tool along the seem while prying up to separate the display housing from the laptop cover.
    • If the touch screen housing is cracked, it may splinter or shatter while separating.
  3. HP Envy x360 15-u473cl Touch Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the four 3mm screws using the Phillips #00 screwdriver.
  4. HP Envy x360 15-u473cl Touch Screen Replacement: 步骤 4 中的图像 1,2 HP Envy x360 15-u473cl Touch Screen Replacement: 步骤 4 中的图像 2,2
    • Lift the white UPC tape using the spudger, and disconnect the the golden connector from the screen.
    • There may be a piece of black tape connecting a bundle of wires to the screen. Remove the piece of black tape if present.
    • Remove the touch screen.
结论
2等其他人完成本指南。
0 Guide Comments
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 22
总计 13,022
