当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Power off your laptop before beginning disassembly.
Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
Turn the device right side up and open the lid.
Insert the plastic opening tool in between the keyboard plate and the base of laptop.
Run the tool along seem, prying up as you go.
Separate the keyboard plate from the base, lifting from the front.
There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
Remove the keyboard plate from the device.
Disconnect the battery from the motherboard.
There may be tamper-proof tape holding the battery in place. Remove the tape if present.
Remove the battery from the device.
On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo Phillips #0 screwdriver.
Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
Lift and pull the front of the battery up and out (away from the connector) to remover.
Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan.
Be careful as the fan might be sharp in some places when removing it.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
