跳转到主内容
HP Envy x360 15-u473cl Fan Replacement
你所需要的
  1. HP Envy x360 15-u473cl Fan Replacement, Battery: 步骤 1 中的图像 1,2 HP Envy x360 15-u473cl Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Power off your laptop before beginning disassembly.
    • Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
    • Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
  2. HP Envy x360 15-u473cl Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the fourteen 7mm screws using the Phillips #0 screwdriver from the bottom of the laptop.
  3. HP Envy x360 15-u473cl Fan Replacement: 步骤 3 中的图像 1,2 HP Envy x360 15-u473cl Fan Replacement: 步骤 3 中的图像 2,2
    • Turn the device right side up and open the lid.
    • Insert the plastic opening tool in between the keyboard plate and the base of laptop.
    • Run the tool along seem, prying up as you go.
    • Separate the keyboard plate from the base, lifting from the front.
  4. HP Envy x360 15-u473cl Fan Replacement: 步骤 4 中的图像 1,1
    • There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
    • Remove the keyboard plate from the device.
  5. HP Envy x360 15-u473cl Fan Replacement: 步骤 5 中的图像 1,1
    • Remove the thick white ribbon cable covering the battery using the plastic opening tool by prying up the latches attaching each end.
  6. HP Envy x360 15-u473cl Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the three 4mm screws using the Phillips #0 screwdriver.
  7. HP Envy x360 15-u473cl Fan Replacement: 步骤 7 中的图像 1,1
    • Disconnect the battery from the motherboard.
    • There may be tamper-proof tape holding the battery in place. Remove the tape if present.
    • Remove the battery from the device.
  8. HP Envy x360 15-u473cl Fan Replacement, Fan: 步骤 8 中的图像 1,1
    • Remove the three 4mm screws using the Phillips #0 screwdriver from the device fan.
  9. HP Envy x360 15-u473cl Fan Replacement: 步骤 9 中的图像 1,2 HP Envy x360 15-u473cl Fan Replacement: 步骤 9 中的图像 2,2
    • Disconnect the fan from the motherboard using the spudger.
    • Remove the fan from the device.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,518
