跳转到主内容
HP Envy x360 15-bp143cl Screen Replacement
你所需要的
  1. HP Envy x360 15-bp143cl Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Use a suction handle to pull the screen display out of the screen casing.
    • If the screen is difficult to remove, use an opening tool to pry the sides of screen from the screen casing.
  2. HP Envy x360 15-bp143cl Screen Replacement: 步骤 2 中的图像 1,2 HP Envy x360 15-bp143cl Screen Replacement: 步骤 2 中的图像 2,2
    • Lift the screen display from the screen casing, hinging it from the top edge to expose the back of the panel.
    • Do not separate the display from the casing completely, as there are still cable connections holding it in place.
  3. HP Envy x360 15-bp143cl Screen Replacement: 步骤 3 中的图像 1,2 HP Envy x360 15-bp143cl Screen Replacement: 步骤 3 中的图像 2,2
    • Detach the connecting cable between the laptop and the display screen.
    • Remove the display screen.
结论
3等其他人完成本指南。
Spencer Berkins
于10/10/19注册
574 声望
创作了4篇指南
团队
Cal Poly, Team S12-G3, Regan Fall 2019 Cal Poly, Team S12-G3, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G3
3 名成员
创作了6篇指南
一条评论
Thank you for this great guide, been very useful knowing how to remove the screen from th housing! However; I'm looking to replace not the screen but the 'screen housing' as the plastic bracket that the hinges screw into (three round flat screws you can see for each hinge) has torn. Very bad design IMHO. The entire screw/bolt has just torn free (all three) on the right hinge. Seeing as the plastic bracket is glued to the metal casing it is irreparable…
Anybody know where I can get the replacement (my HP Envy has a metal/aluminium housing in silver colour).
Kind regards,
Adrian
Adrian Munro - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 108
总计 4,140
