跳转到主内容
HP Envy x360 15-bp143cl Daughterboard Replacement
你所需要的
  1. HP Envy x360 15-bp143cl Daughterboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Daughterboard Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Daughterboard Replacement: 步骤 3 中的图像 1,1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Daughterboard Replacement: 步骤 4 中的图像 1,1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Daughterboard Replacement: 步骤 5 中的图像 1,2 HP Envy x360 15-bp143cl Daughterboard Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Daughterboard Replacement: 步骤 6 中的图像 1,1
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl Daughterboard Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Peel off the tape securing the heatsink.
  8. HP Envy x360 15-bp143cl Daughterboard Replacement: 步骤 8 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the seven 4 mm screws securing the fan.
    • Detach the fan cable from the mother board.
  9. HP Envy x360 15-bp143cl Daughterboard Replacement: 步骤 9 中的图像 1,1
    • Lift the fan up and off the motherboard.
  10. HP Envy x360 15-bp143cl Daughterboard Replacement: 步骤 10 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the ten 4 mm screws securing the motherboard.
    • Pull the four cables directly out of their ports.
    • Flip up the lock-bar on the two ZIF connectors, then gently pull the two ribbon cables directly out of their ports.
  11. HP Envy x360 15-bp143cl Daughterboard Replacement: 步骤 11 中的图像 1,1
    • Gently lift the motherboard up and out of the chassis.
  12. HP Envy x360 15-bp143cl Daughterboard Replacement, Daughterboard: 步骤 12 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the single 4 mm screw securing the daughterboard.
    • Disconnect the ribbon cable.
  13. HP Envy x360 15-bp143cl Daughterboard Replacement: 步骤 13 中的图像 1,1
    • Gently lift the daughterboard up and out of the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 219
