跳转到主内容
HP Envy x360 15-bp143cl Battery Replacement
你所需要的
  1. HP Envy x360 15-bp143cl Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Battery Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Battery Replacement: 步骤 3 中的图像 1,1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Battery Replacement: 步骤 4 中的图像 1,1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Battery Replacement: 步骤 5 中的图像 1,2 HP Envy x360 15-bp143cl Battery Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl Battery Replacement: 步骤 6 中的图像 1,1
    • Pull the battery from the connecting port and lift to remove it from the laptop.
结论
3等其他人完成本指南。
Riley Muehler
于10/10/19注册
320 声望
撰写一个指南
团队
Cal Poly, Team S12-G3, Regan Fall 2019 Cal Poly, Team S12-G3, Regan Fall 2019 的会员
CPSU-REGAN-F19S12G3
3 名成员
创作了6篇指南
一条评论
Thank you for the pictures and advice!
I did not see any memory. Can you tell me if there are two slots for upgrading? I read that one stick of memory is soldered and the other is socketed.
Regards!
Joseph Stateson - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 26
过去 30 天: 103
总计 3,362
