跳转到主内容
HP Envy x2 13-j002dx Motherboard Replacement
你所需要的
  1. HP Envy x2 13-j002dx Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
  2. HP Envy x2 13-j002dx Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the two 3.5 mm screws from the bottom of the device—one on each side of the keyboard dock.
  3. HP Envy x2 13-j002dx Motherboard Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to remove the screw covers on the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws.
  4. HP Envy x2 13-j002dx Motherboard Replacement: 步骤 4 中的图像 1,2 HP Envy x2 13-j002dx Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use an opening pick to remove the plastic cover above the back stand.
    • Pry the cover off.
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws.
  5. HP Envy x2 13-j002dx Motherboard Replacement: 步骤 5 中的图像 1,1
    • Use an opening pick and a prying tool, and go around the device to remove the back cover from the rest of the assembly.
  6. HP Envy x2 13-j002dx Motherboard Replacement: 步骤 6 中的图像 1,1
    • Unplug the battery from the motherboard.
  7. HP Envy x2 13-j002dx Motherboard Replacement: 步骤 7 中的图像 1,2 HP Envy x2 13-j002dx Motherboard Replacement: 步骤 7 中的图像 2,2
    • Carefully pull up on the battery connector from the speaker.
    • Use a pair of tweezers and remove the taped down wire for the speaker.
    • Use a Phillips #00 screwdriver to remove the seven 3mm screws around the battery.
  8. HP Envy x2 13-j002dx Motherboard Replacement: 步骤 8 中的图像 1,1
    • Carefully lift up and remove the battery.
  9. HP Envy x2 13-j002dx Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Before removing the motherboard, clear away any dust, and ensure that the battery is already removed.
  10. HP Envy x2 13-j002dx Motherboard Replacement: 步骤 10 中的图像 1,2 HP Envy x2 13-j002dx Motherboard Replacement: 步骤 10 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the three 3.8 mm screws along the edge of the motherboard.
  11. HP Envy x2 13-j002dx Motherboard Replacement: 步骤 11 中的图像 1,2 HP Envy x2 13-j002dx Motherboard Replacement: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Disconnect the cable connectors from the motherboard. This can be done with either tweezers or with your fingers.
  12. HP Envy x2 13-j002dx Motherboard Replacement: 步骤 12 中的图像 1,2 HP Envy x2 13-j002dx Motherboard Replacement: 步骤 12 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the 3.2mm screws within the copper rings in the circuit board.
    • Using the Phillips #0 screwdriver, remove the 2.5mm and 4.25mm black screws on the motherboard.
  13. HP Envy x2 13-j002dx Motherboard Replacement: 步骤 13 中的图像 1,1
    • Once the screws and cables are disconnected and removed, remove the motherboard from the frame.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 26
总计 578
