跳转到主内容
HP Envy x2 13-j002dx Battery Replacement
你所需要的
  1. HP Envy x2 13-j002dx Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
  2. HP Envy x2 13-j002dx Battery Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the two 3.5 mm screws from the bottom of the device—one on each side of the keyboard dock.
  3. HP Envy x2 13-j002dx Battery Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to remove the screw covers on the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws.
  4. HP Envy x2 13-j002dx Battery Replacement: 步骤 4 中的图像 1,2 HP Envy x2 13-j002dx Battery Replacement: 步骤 4 中的图像 2,2
    • Use an opening pick to remove the plastic cover above the back stand.
    • Pry the cover off.
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws.
  5. HP Envy x2 13-j002dx Battery Replacement: 步骤 5 中的图像 1,1
    • Use an opening pick and a prying tool, and go around the device to remove the back cover from the rest of the assembly.
  6. HP Envy x2 13-j002dx Battery Replacement: 步骤 6 中的图像 1,1
    • Unplug the battery from the motherboard.
  7. HP Envy x2 13-j002dx Battery Replacement: 步骤 7 中的图像 1,2 HP Envy x2 13-j002dx Battery Replacement: 步骤 7 中的图像 2,2
    • Carefully pull up on the battery connector from the speaker.
    • Use a pair of tweezers and remove the taped down wire for the speaker.
    • Use a Phillips #00 screwdriver to remove the seven 3mm screws around the battery.
  8. HP Envy x2 13-j002dx Battery Replacement: 步骤 8 中的图像 1,1
    • Carefully lift up and remove the battery.
结论
5等其他人完成本指南。
一条评论
For step 2, when I was taking the screws out, they were held in by the magnets that were on either side of them making it difficult to remove. I ended up having to use another magnet to get them out.
Reed Jochimsen - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 22
总计 1,910
