跳转到主内容
HP Envy m6-p114dx Battery Replacement
你所需要的
  1. HP Envy m6-p114dx Battery Replacement, Back Panel: 步骤 1 中的图像 1,3 HP Envy m6-p114dx Battery Replacement, Back Panel: 步骤 1 中的图像 2,3 HP Envy m6-p114dx Battery Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Power the device off, unplug it, and ground yourself.
  2. HP Envy m6-p114dx Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the twelve screws in the back case using a Phillips #1 screwdriver.
  3. HP Envy m6-p114dx Battery Replacement: 步骤 3 中的图像 1,1
    • Carefully wedge an iFixit opening tool under the cover and slide it alongside the case to ensure that all clips are un-clipped.
  4. HP Envy m6-p114dx Battery Replacement, Battery: 步骤 4 中的图像 1,2 HP Envy m6-p114dx Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the cable connecting the hard drive to the motherboard by carefully lifting the black tab, then pulling out the disconnected ribbon cable.
  5. HP Envy m6-p114dx Battery Replacement: 步骤 5 中的图像 1,2 HP Envy m6-p114dx Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the cable connecting the battery to the motherboard by gripping the fabric and pulling downward.
    • The cable is connected next to the RAM cards.
  6. HP Envy m6-p114dx Battery Replacement: 步骤 6 中的图像 1,2 HP Envy m6-p114dx Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the six screws that hold the battery down with a Phillips #0 screwdriver.
    • Once the screws are removed you should be able to easily lift up on the battery to remove it. (You may need to detach the ribbon cable glued to the battery )
结论
另外一个人完成了本指南。
Taylor Cheney
于08/26/19注册
527 声望
创作了4篇指南
团队
Gateway, Team S1-G1, Saknee Fall 2019 Gateway, Team S1-G1, Saknee Fall 2019 的会员
GCC-SAKNEE-F19S1G1
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 13
总计 1,006
