简介
This guide demonstrates how to properly remove the RAM of a HP Envy m6-n010dx.
  1. Find the battery removal slider.
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. Remove the five marked screws found under the battery using a philips head screwdriver.
    • Remove the five marked screws found under the battery using a philips head screwdriver.
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
    • Remove the highlighted screws
    • Pry off the lower two grip pads
      • You may need to use more force than feels necessary
    • Remove the two additional screws underneath the lower grip pads
    • Remove the large back panel to reveal the inner workings
      • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
    • Pull back the black rectangular cover to reveal the RAM
    • Unclip the metal restraints on the side to pop out the RAM
    • Repeat the previous step for the second RAM below
结论
Johnathan Morales
于2018年02月08日注册
354 信誉积分
创作了3篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 73
