跳转到主内容
HP Envy m6-k022dx Speaker Replacement
你所需要的
  1. HP Envy m6-k022dx Speaker Replacement, Lower Case: 步骤 1 中的图像 1,1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx Speaker Replacement: 步骤 2 中的图像 1,1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx Speaker Replacement: 步骤 3 中的图像 1,1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx Speaker Replacement: 步骤 4 中的图像 1,1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
    • Remove the two screws holding the speaker in place.
    • There are two red rubber grommets which stay situated in the screw guide holes; be sure not to lose these.
  6. HP Envy m6-k022dx Speaker Replacement: 步骤 6 中的图像 1,1
    • Once the screws have been removed, gently lift the speaker straight up, but just enough to dislodge it.
    • There is a cable connecting the speakers to the sound board. Be sure to not tug on this connection when lifting the speaker.
  7. HP Envy m6-k022dx Speaker Replacement: 步骤 7 中的图像 1,1
    • Once the speaker is dislodged, gently pull the connecting cable from the sound card.
    • The speaker is now fully removed and ready to be replaced.
结论
另外一个人完成了本指南。
Kareem Rigaud
于03/02/17注册
403 声望
创作了3篇指南
团队
USF Tampa, Team S13-G6, Cagle Spring 2017 USF Tampa, Team S13-G6, Cagle Spring 2017 的会员
USFT-CAGLE-S17S13G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 670
