跳转到主内容
HP Envy m6-k022dx CPU Fan Replacement
你所需要的
  1. HP Envy m6-k022dx CPU Fan Replacement, Lower Case: 步骤 1 中的图像 1,1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx CPU Fan Replacement: 步骤 2 中的图像 1,1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx CPU Fan Replacement: 步骤 3 中的图像 1,1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx CPU Fan Replacement: 步骤 4 中的图像 1,1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx CPU Fan Replacement, CPU Fan: 步骤 5 中的图像 1,1
    • The fan is located here. You will need to remove three screws in order to lift the fan out from the motherboard.
    • You will need a Phillips 00 size screwdriver to remove the screws.
  6. HP Envy m6-k022dx CPU Fan Replacement: 步骤 6 中的图像 1,1
    • Use your screwdriver to remove the three screws connecting the fan to the motherboard.
  7. HP Envy m6-k022dx CPU Fan Replacement: 步骤 7 中的图像 1,1
    • Grab the fan with your hand, and lift up and away from the motherboard.
  8. HP Envy m6-k022dx CPU Fan Replacement: 步骤 8 中的图像 1,1
    • Grab the fan power connector by the wires and pull directly away from port until the cable is disconnected.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team S13-G6, Cagle Spring 2017 USF Tampa, Team S13-G6, Cagle Spring 2017 的会员
USFT-CAGLE-S17S13G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 11
总计 803
