简介
Use this guide to replace a faulty hard drive on your HP Envy dv7t-7200 if your laptop is running slowly, begins freezing, or has corrupt files. There are two hard drives within this laptop that can be removed and replaced in a few steps.
你所需要的
Place the computer on its top on a flat surface with the hinges facing away from you.
Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
To reassemble your device, follow these instructions in the reverse order.
另外一个人完成了本指南。
