跳转到主内容
HP Envy Touchsmart m6-k125dx Touch Screen Replacement
你所需要的
  1. HP Envy Touchsmart m6-k125dx Touch Screen Replacement, Touch Screen: 步骤 1 中的图像 1,1
    • Open the laptop.
    • Remove black tabs at bottom left and right corners and remove the two M2.5x2.5 screws behind the black tabs with the J0 screwdriver.
  2. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: 步骤 2 中的图像 1,2 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: 步骤 2 中的图像 2,2
    • Insert pick between the black plastic screen panel and the silver plastic exterior case on the side of the device.
    • Slide pick around the border of the screen panel while keeping the pick between the mentioned panel and exterior case.
    • Repeat previous two steps until exterior case is removed. Pry with minimal force if necessary.
  3. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: 步骤 3 中的图像 1,3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: 步骤 3 中的图像 2,3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: 步骤 3 中的图像 3,3
    • Remove the front panel from the rest of the device and set it aside.
    • Remove the ten M2.5x2.5 screws with the J0 screwdriver.
    • Remove the eight M2.0x2.0 screws with the J0 screwdriver.
  4. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: 步骤 4 中的图像 1,3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: 步骤 4 中的图像 2,3 HP Envy Touchsmart m6-k125dx Touch Screen Replacement: 步骤 4 中的图像 3,3
    • Flip hinges down and away from the rest of the panel.
    • Remove the four M2.5x2.5 screws with the J0 screwdriver.
    • Move 4 pieces of black tape across the bottom of the panel and any other accessory tape.
    • Disconnect the display cable connector that is located at the bottom right of the panel by pulling lightly.
  5. HP Envy Touchsmart m6-k125dx Touch Screen Replacement: 步骤 5 中的图像 1,1
    • Slowly lift the screen away from the touch screen front panel to remove.
结论
2等其他人完成本指南。
团队
IUPUI, Team S14-G14, Wilson Spring 2019 IUPUI, Team S14-G14, Wilson Spring 2019 的会员
IUPUI-WILSON-S19S14G14
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 870
