跳转到主内容
HP Envy TouchSmart m7 k010dx Battery Replacement
  1. HP Envy TouchSmart m7 k010dx Battery Replacement, Battery: 步骤 1 中的图像 1,3 HP Envy TouchSmart m7 k010dx Battery Replacement, Battery: 步骤 1 中的图像 2,3 HP Envy TouchSmart m7 k010dx Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn your computer over so that the bottom is facing up.
    • Slide the left black switch towards center.
    • You should see an unlock image exposed to the left of switch if done correctly.
  2. HP Envy TouchSmart m7 k010dx Battery Replacement: 步骤 2 中的图像 1,2 HP Envy TouchSmart m7 k010dx Battery Replacement: 步骤 2 中的图像 2,2
    • Slide the right black switch towards center to release the battery.
  3. HP Envy TouchSmart m7 k010dx Battery Replacement: 步骤 3 中的图像 1,2 HP Envy TouchSmart m7 k010dx Battery Replacement: 步骤 3 中的图像 2,2
    • Pivot the loose edge of the battery closes to you by pushing it toward the back of the computer.
    • The battery should slide out freely.
    • If battery is not pivoted before sliding out, you risk breaking interlocking tabs on the battery or computer.
结论
另外一个人完成了本指南。
Owen Ou
于10/17/17注册
443 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 745
