简介
If you are having audio issues with your laptop, you may need to replace the speaker. This guide details how to replace the speakers in an HP Envy TouchSmart m6-k025dx Sleekbook laptop.
你所需要的
Flip the laptop over so that the backside of the laptop is facing upwards.
Use the Phillips #0 screwdriver to remove the twelve 5 mm screws that secure the bottom cover.
Insert a plastic opening tool into the opening between the bottom and top cover. Gently work your way around the perimeter of the case, and pry the two halves apart until the back cover is free from the laptop.
