简介
Over time, the battery life of any laptop is sure to deplete. This replacement guide provides instructions for replacing a battery on the HP Envy TouchSmart m6-k025dx Sleekbook. All you will need is a Phillips #0 screwdriver and a plastic opening tool. It is an easy process and should not take much longer than 10 minutes. Enjoy!
你所需要的
Flip the laptop over so that the backside of the laptop is facing upwards.
Use the Phillips #0 screwdriver to remove the twelve 5 mm screws that secure the bottom cover.
Insert a plastic opening tool into the opening between the bottom and top cover. Gently work your way around the perimeter of the case, and pry the two halves apart until the back cover is free from the laptop.
