跳转到主内容
HP Envy TouchSmart 4-1215dx Display Replacement
你所需要的
  1. HP Envy TouchSmart 4-1215dx Display Replacement, Display: 步骤 1 中的图像 1,1
    • Remove both 3 mm screws at the bottom of the display using a Phillips #0 screwdriver.
  2. HP Envy TouchSmart 4-1215dx Display Replacement: 步骤 2 中的图像 1,2 HP Envy TouchSmart 4-1215dx Display Replacement: 步骤 2 中的图像 2,2
    • Using an iFixit opening tool, pry the screen from the back panel.
    • Remove the back panel.
  3. HP Envy TouchSmart 4-1215dx Display Replacement: 步骤 3 中的图像 1,1
    • Close the laptop so the front is facing you.
    • Remove the four 3 mm screws from the two brackets at the front using a Phillips #0 screwdriver.
    • Remove the brackets.
  4. HP Envy TouchSmart 4-1215dx Display Replacement: 步骤 4 中的图像 1,3 HP Envy TouchSmart 4-1215dx Display Replacement: 步骤 4 中的图像 2,3 HP Envy TouchSmart 4-1215dx Display Replacement: 步骤 4 中的图像 3,3
    • Remove the 3 mm screws from the back brackets using a Phillips #0 screwdriver.
    • Remove the 1 mm screws with a Phillips #00 screwdriver.
    • Lift up the display until the brackets are sticking straight up.
  5. HP Envy TouchSmart 4-1215dx Display Replacement: 步骤 5 中的图像 1,1
    • Peel off the aluminum tape located at the top of the display.
  6. HP Envy TouchSmart 4-1215dx Display Replacement: 步骤 6 中的图像 1,2 HP Envy TouchSmart 4-1215dx Display Replacement: 步骤 6 中的图像 2,2
    • Disconnect the ribbon cable and peel off the connected tape from the display.
  7. HP Envy TouchSmart 4-1215dx Display Replacement: 步骤 7 中的图像 1,2 HP Envy TouchSmart 4-1215dx Display Replacement: 步骤 7 中的图像 2,2
    • Lift the display up separately from the screen.
    • Peel off the orange tape at the bottom of the display connecting to the laptop.
  8. HP Envy TouchSmart 4-1215dx Display Replacement: 步骤 8 中的图像 1,1
    • Lift up the display.
    • If your display is cracked or shattered, you should tape up the effected parts in order to avoid injury.
结论
Isaac York
于02/08/22注册
157 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 229
