跳转到主内容
HP Envy TouchSmart 15 Solid State Drive Replacement
你所需要的
  1. HP Envy TouchSmart 15 Solid State Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Solid State Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Solid State Drive Replacement, Accessory Plate: 步骤 3 中的图像 1,2 HP Envy TouchSmart 15 Solid State Drive Replacement, Accessory Plate: 步骤 3 中的图像 2,2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Solid State Drive Replacement: 步骤 4 中的图像 1,3 HP Envy TouchSmart 15 Solid State Drive Replacement: 步骤 4 中的图像 2,3 HP Envy TouchSmart 15 Solid State Drive Replacement: 步骤 4 中的图像 3,3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Solid State Drive Replacement, Solid State Drive: 步骤 5 中的图像 1,2 HP Envy TouchSmart 15 Solid State Drive Replacement, Solid State Drive: 步骤 5 中的图像 2,2
    • Remove the PM 2.0x2.5 screw with the PH#0 Screwdriver attachment that is shown at the corner of the Solid State Drive.
    • After you have removed the screw, the Solid State Drive should lift up.
  6. HP Envy TouchSmart 15 Solid State Drive Replacement: 步骤 6 中的图像 1,2 HP Envy TouchSmart 15 Solid State Drive Replacement: 步骤 6 中的图像 2,2
    • Very carefully, remove the SSD by gently pulling away from the SSD socket.
结论
4等其他人完成本指南。
Ramon Villadonga
于09/04/15注册
1,041 声望
创作了5篇指南
团队
USF Tampa, Team 2-6, Sullivan Fall 2015 USF Tampa, Team 2-6, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G6
4 名成员
创作了10篇指南
2指南评论
Please what type of ssd is that and can i get the specifications? I want to get one for my laptop since it didn’t ship with it. Its the same as the one above. HP ENVY TS 15 Notebook PC Thanks.
temidayoabayomizannu - 回复
Wht type of ssd i can insert here
Plz help me
Kavindra Danushka Rajapaksha - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 17
总计 3,156
