跳转到主内容
HP Envy TouchSmart 15 Hard Drive Replacement
你所需要的
  1. HP Envy TouchSmart 15 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Hard Drive Replacement, Accessory Plate: 步骤 3 中的图像 1,2 HP Envy TouchSmart 15 Hard Drive Replacement, Accessory Plate: 步骤 3 中的图像 2,2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Hard Drive Replacement: 步骤 4 中的图像 1,3 HP Envy TouchSmart 15 Hard Drive Replacement: 步骤 4 中的图像 2,3 HP Envy TouchSmart 15 Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,2 HP Envy TouchSmart 15 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to pry the hard drive away from the board. Notice that there is a slit centered at the back of where the hard drive is sitting. This is where you'll insert the plastic opening tool as shown in the photo. Finally, pry with the plastic opening tool to remove the hard drive.
  6. HP Envy TouchSmart 15 Hard Drive Replacement: 步骤 6 中的图像 1,2 HP Envy TouchSmart 15 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Firmly grasp the connector's base as shown and pull to remove from the hard drive.
结论
11等其他人完成本指南。
Ramon Villadonga
于09/04/15注册
1,029 声望
创作了5篇指南
团队
USF Tampa, Team 2-6, Sullivan Fall 2015 USF Tampa, Team 2-6, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G6
4 名成员
创作了10篇指南
6条评论
Thanks man! Worked great.
Charles Uibel - 回复
Thank you! I was worried about the step to remove the accessory plate, but seeing this tutorial helped reassure me that I wasn't going to break it. Very interesting design choice by HP...
Rob Kachmar - 回复
What’s the hard disk size in case I want to buy a replacement? In terms of inches. I see online that most of the laptop hard disks are quoted as 2.5 or 3 inch
Bwana Lawi - 回复
2.5 inches. I fitted the Samsung 850 EVO, fits perfectly.
cbrowne91 - 回复
Thanks found the guide helpful. However I caused myself a problem by breaking the black hdd retaining clip on the motherboard. It was so fragile that I’m sure this has happened to others???? Any repair ideas anyone? As you imagine I’d be grateful of a resolution.
Arthur David Mc Kee - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 39
总计 12,655
