跳转到主内容
HP Envy TouchSmart 15 Digitizer Replacement
你所需要的
  1. HP Envy TouchSmart 15 Digitizer Replacement, Touch Screen/Digitizer: 步骤 1 中的图像 1,1
    • Lay the laptop down with the bottom facing up.
  2. HP Envy TouchSmart 15 Digitizer Replacement: 步骤 2 中的图像 1,1
    • Slide the switch to release the battery and remove it.
  3. HP Envy TouchSmart 15 Digitizer Replacement: 步骤 3 中的图像 1,2 HP Envy TouchSmart 15 Digitizer Replacement: 步骤 3 中的图像 2,2
    • Remove the screw from the access panel. Gently lift and remove the panel.
  4. HP Envy TouchSmart 15 Digitizer Replacement: 步骤 4 中的图像 1,3 HP Envy TouchSmart 15 Digitizer Replacement: 步骤 4 中的图像 2,3 HP Envy TouchSmart 15 Digitizer Replacement: 步骤 4 中的图像 3,3
    • Remove the hard drive and disconnect its ribbon cable from both the hard drive and the motherboard.
  5. HP Envy TouchSmart 15 Digitizer Replacement: 步骤 5 中的图像 1,3 HP Envy TouchSmart 15 Digitizer Replacement: 步骤 5 中的图像 2,3 HP Envy TouchSmart 15 Digitizer Replacement: 步骤 5 中的图像 3,3
    • Remove the screws to loosen the bottom casing.
    • Remove the two feet to reveal the screws underneath.
  6. HP Envy TouchSmart 15 Digitizer Replacement: 步骤 6 中的图像 1,1
    • Gently pry the edges to loosen the case.
    • Once loose, lift and remove the plastic casing to reveal the motherboard.
  7. HP Envy TouchSmart 15 Digitizer Replacement: 步骤 7 中的图像 1,2 HP Envy TouchSmart 15 Digitizer Replacement: 步骤 7 中的图像 2,2
    • Lift and detach the wireless antenna cables.
    • Lift and de-route the wires from their tracks until you reach the display hinges.
  8. HP Envy TouchSmart 15 Digitizer Replacement: 步骤 8 中的图像 1,1
    • Detach the two cables. Lift the tab for the ribbon cable before pulling it out.
  9. HP Envy TouchSmart 15 Digitizer Replacement: 步骤 9 中的图像 1,2 HP Envy TouchSmart 15 Digitizer Replacement: 步骤 9 中的图像 2,2
    • Remove the screws from each hinge.
    • Lift the hinges with pliers until they are perpendicular to the case.
    • Lift and remove the bottom of the laptop from the screen.
  10. HP Envy TouchSmart 15 Digitizer Replacement: 步骤 10 中的图像 1,1
    • Lift the tabs in both the bottom corners and remove the screws beneath.
  11. HP Envy TouchSmart 15 Digitizer Replacement: 步骤 11 中的图像 1,2 HP Envy TouchSmart 15 Digitizer Replacement: 步骤 11 中的图像 2,2
    • Using a pry tool as necessary, remove the digitizer from the rest of the screen panel. Be careful around the top edge as there are delicate components beneath.
  12. HP Envy TouchSmart 15 Digitizer Replacement: 步骤 12 中的图像 1,3 HP Envy TouchSmart 15 Digitizer Replacement: 步骤 12 中的图像 2,3 HP Envy TouchSmart 15 Digitizer Replacement: 步骤 12 中的图像 3,3
    • Using a heat gun, carefully loosen the adhesive connecting the digitizer to its plastic border.
    • Gently peel the digitizer away from the plastic border.
    • When installing the new one digitizer, press firmly around the edges.
结论
5等其他人完成本指南。
Micah Kempf
于03/30/16注册
260 声望
撰写一个指南
团队
Michigan Tech, Team 1-12, Lauer Spring 2016 Michigan Tech, Team 1-12, Lauer Spring 2016 的会员
MTU-LAUER-S16S1G12
1 名成员
创作了1篇指南
4条评论
These directions are perfect. I was able to successfully change my digitizer in under an hour
Joe Russo - 回复
where do you get the digitizer?
Jacob - 回复
Amazing,
My name is Nevelson, I have exactly same laptop and mine also is broke, but I don't know where to get the replacement; only the sensor, please I need help and willing to pay handsomely.
Nevelson Odimgbe - 回复
Nevelson, I have updated this page to included a link to the part on amazon.
Micah Kempf - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 14,196
