跳转到主内容
HP Envy Sleekbook m6-k010dx LCD Replacement
你所需要的
  1. HP Envy Sleekbook m6-k010dx LCD Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 2 中的图像 1,2 HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 3 中的图像 1,1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 4 中的图像 1,1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 5 中的图像 1,2 HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 5 中的图像 2,2
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: 步骤 6 中的图像 1,2 HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: 步骤 6 中的图像 2,2
    • Remove the stickers from the bottom left and right corner of the device with a plastic opening tool.
  7. HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 7 中的图像 1,1
    • Remove the two 2.5mm Phillips #00 screws found underneath the previously removed stickers.
  8. HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 8 中的图像 1,3 HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 8 中的图像 2,3 HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 8 中的图像 3,3
    • Use the plastic opening tool to pry the bezel free from the LCD housing.
  9. HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 9 中的图像 1,2 HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 9 中的图像 2,2
    • Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen.
  10. HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 10 中的图像 1,2 HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 10 中的图像 2,2
    • Use the plastic opening tool to remove the LCD screen from its housing.
    • Lay the LCD screen flat on the keyboard.
  11. HP Envy Sleekbook m6-k010dx LCD Replacement: 步骤 11 中的图像 1,1
    • Disconnect the cable which connects the LCD to the motherboard.
    • Pul the LCD screen out.
结论
2等其他人完成本指南。
codi whittaker
于02/14/18注册
508 声望
创作了3篇指南
团队
USF Tampa, Team S1-G4, Nance Spring 2018 USF Tampa, Team S1-G4, Nance Spring 2018 的会员
USFT-NANCE-S18S1G4
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 919
