简介
To replace your hard drive, first remove the current one from the black rubber sleeves and put the rubber sleeves on your new hard drive. Make sure you have your new drive oriented correctly so you can plug it back in.
你所需要的
Remove the two black 6.35mm PH #0 screws with a screwdriver from the top of the hard drive.
Remove the two silver 6.35mm PH#0 screws from the bottom of the hard drive.
即将完成!
结论
6等其他人完成本指南。
