跳转到主内容
HP Envy M6-1205DX Hinge Replacement
你所需要的
  1. HP Envy M6-1205DX Hinge Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Hinge Replacement: 步骤 2 中的图像 1,1
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Hinge Replacement: 步骤 3 中的图像 1,2 HP Envy M6-1205DX Hinge Replacement: 步骤 3 中的图像 2,2
    • Remove the battery.
  4. HP Envy M6-1205DX Hinge Replacement, Touchpad: 步骤 4 中的图像 1,1
    • Using a Phillips #1, remove the 8 10.6mm screws.
    • Also using a Phillips #1, remove the 8.6mm screw.
  5. HP Envy M6-1205DX Hinge Replacement: 步骤 5 中的图像 1,1
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Hinge Replacement: 步骤 6 中的图像 1,1
    • Using a Phillips #1, remove the 3.5mm screw.
    • Our computer did not come with a hard drive so you should have one in the empty hole. We have marked where we believe the screws will be in orange.
    • Using a Phillips #1, remove the four 10.6mm screws.
  7. HP Envy M6-1205DX Hinge Replacement: 步骤 7 中的图像 1,1
    • Pull the disk drive out to remove it.
  8. HP Envy M6-1205DX Hinge Replacement: 步骤 8 中的图像 1,2 HP Envy M6-1205DX Hinge Replacement: 步骤 8 中的图像 2,2
    • Using a Phillips #1, remove the two 2.4mm screws.
  9. HP Envy M6-1205DX Hinge Replacement: 步骤 9 中的图像 1,2 HP Envy M6-1205DX Hinge Replacement: 步骤 9 中的图像 2,2
    • Flip the black tab up on the clamp that holds the ribbon cable in place.
    • Pull the cable back with your fingers or a pair of tweezers.
  10. HP Envy M6-1205DX Hinge Replacement: 步骤 10 中的图像 1,2 HP Envy M6-1205DX Hinge Replacement: 步骤 10 中的图像 2,2
    • Flip the computer back over
    • Use the plastic opening tool to pry the keyboard up .
  11. HP Envy M6-1205DX Hinge Replacement: 步骤 11 中的图像 1,3 HP Envy M6-1205DX Hinge Replacement: 步骤 11 中的图像 2,3 HP Envy M6-1205DX Hinge Replacement: 步骤 11 中的图像 3,3
    • Carefully lift the keyboard up.
    • Flip up the black tab holding the large ribbon cable down.
    • Push both sides of the small white tab forward to release the small ribbon cable.
    • Pull both the cables out to remove them.
    • Remove the keyboard.
  12. HP Envy M6-1205DX Hinge Replacement: 步骤 12 中的图像 1,3 HP Envy M6-1205DX Hinge Replacement: 步骤 12 中的图像 2,3 HP Envy M6-1205DX Hinge Replacement: 步骤 12 中的图像 3,3
    • Flip the small white tab up to release the ribbon cable.
    • Pull to remove.
    • Repeat the same steps for the other cable.
  13. HP Envy M6-1205DX Hinge Replacement: 步骤 13 中的图像 1,1
    • Using a Phillips #1, remove the four 5.6mm silver screws.
  14. HP Envy M6-1205DX Hinge Replacement: 步骤 14 中的图像 1,2 HP Envy M6-1205DX Hinge Replacement: 步骤 14 中的图像 2,2
    • Use the plastic opening tool to pry the face plate off the rest of the frame.
    • Once you pry all of the snaps up lift the face plate off.
  15. HP Envy M6-1205DX Hinge Replacement, Hinges: 步骤 15 中的图像 1,2 HP Envy M6-1205DX Hinge Replacement, Hinges: 步骤 15 中的图像 2,2
    • Pull up on the black tab to unplug the cable that goes into the screen
    • The cable will be stuck onto the motherboard and will need to be pulled off. The adhesive is very weak and the cable will stick back down when you are finished.
  16. HP Envy M6-1205DX Hinge Replacement: 步骤 16 中的图像 1,1
    • Using a Phillps #1, remove the two 5.6mm silver screws from the base of the first hinge.
  17. HP Envy M6-1205DX Hinge Replacement: 步骤 17 中的图像 1,1
    • Also using a Phillips #1, remove the two 5.6mm silver screws from the base of the second hinge.
  18. HP Envy M6-1205DX Hinge Replacement: 步骤 18 中的图像 1,1
    • Using a plastic opening tool, carefully start prying the frame of the screen up
  19. HP Envy M6-1205DX Hinge Replacement: 步骤 19 中的图像 1,1
    • When prying the screen frame off be careful around the top edge as your webcam will be there. It is a safe idea to move it out of the way like am I doing now.
  20. HP Envy M6-1205DX Hinge Replacement: 步骤 20 中的图像 1,1
    • Remove the three 1.9mm silver screws from the base of the screen frame using the Phillips 00 screwdriver.
    • If you are doing this guide as a prerequisite to replace the screen, stop here and skip ahead to step 23
  21. HP Envy M6-1205DX Hinge Replacement: 步骤 21 中的图像 1,2 HP Envy M6-1205DX Hinge Replacement: 步骤 21 中的图像 2,2
    • Carefully pry the edge of the frame up to expose the other half of the first hinge.
    • Using a Phillips #1, remove the three 2.8mm silver screws.
    • Pull the hinge out.
  22. HP Envy M6-1205DX Hinge Replacement: 步骤 22 中的图像 1,2 HP Envy M6-1205DX Hinge Replacement: 步骤 22 中的图像 2,2
    • Care full pry up the other corner of the frame
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 6,957
