跳转到主内容
HP Envy M6-1205DX Fan Replacement
你所需要的
  1. HP Envy M6-1205DX Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Fan Replacement: 步骤 2 中的图像 1,1
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Fan Replacement: 步骤 3 中的图像 1,2 HP Envy M6-1205DX Fan Replacement: 步骤 3 中的图像 2,2
    • Remove the battery.
  4. HP Envy M6-1205DX Fan Replacement, Touchpad: 步骤 4 中的图像 1,1
    • Using a Phillips #1, remove the 8 10.6mm screws.
    • Also using a Phillips #1, remove the 8.6mm screw.
  5. HP Envy M6-1205DX Fan Replacement: 步骤 5 中的图像 1,1
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Fan Replacement: 步骤 6 中的图像 1,1
    • Using a Phillips #1, remove the 3.5mm screw.
    • Our computer did not come with a hard drive so you should have one in the empty hole. We have marked where we believe the screws will be in orange.
    • Using a Phillips #1, remove the four 10.6mm screws.
  7. HP Envy M6-1205DX Fan Replacement: 步骤 7 中的图像 1,1
    • Pull the disk drive out to remove it.
  8. HP Envy M6-1205DX Fan Replacement: 步骤 8 中的图像 1,2 HP Envy M6-1205DX Fan Replacement: 步骤 8 中的图像 2,2
    • Using a Phillips #1, remove the two 2.4mm screws.
  9. HP Envy M6-1205DX Fan Replacement: 步骤 9 中的图像 1,2 HP Envy M6-1205DX Fan Replacement: 步骤 9 中的图像 2,2
    • Flip the black tab up on the clamp that holds the ribbon cable in place.
    • Pull the cable back with your fingers or a pair of tweezers.
  10. HP Envy M6-1205DX Fan Replacement: 步骤 10 中的图像 1,2 HP Envy M6-1205DX Fan Replacement: 步骤 10 中的图像 2,2
    • Flip the computer back over
    • Use the plastic opening tool to pry the keyboard up .
  11. HP Envy M6-1205DX Fan Replacement: 步骤 11 中的图像 1,3 HP Envy M6-1205DX Fan Replacement: 步骤 11 中的图像 2,3 HP Envy M6-1205DX Fan Replacement: 步骤 11 中的图像 3,3
    • Carefully lift the keyboard up.
    • Flip up the black tab holding the large ribbon cable down.
    • Push both sides of the small white tab forward to release the small ribbon cable.
    • Pull both the cables out to remove them.
    • Remove the keyboard.
  12. HP Envy M6-1205DX Fan Replacement: 步骤 12 中的图像 1,3 HP Envy M6-1205DX Fan Replacement: 步骤 12 中的图像 2,3 HP Envy M6-1205DX Fan Replacement: 步骤 12 中的图像 3,3
    • Flip the small white tab up to release the ribbon cable.
    • Pull to remove.
    • Repeat the same steps for the other cable.
  13. HP Envy M6-1205DX Fan Replacement: 步骤 13 中的图像 1,1
    • Using a Phillips #1, remove the four 5.6mm silver screws.
  14. HP Envy M6-1205DX Fan Replacement: 步骤 14 中的图像 1,2 HP Envy M6-1205DX Fan Replacement: 步骤 14 中的图像 2,2
    • Use the plastic opening tool to pry the face plate off the rest of the frame.
    • Once you pry all of the snaps up lift the face plate off.
  15. HP Envy M6-1205DX Fan Replacement, Fan: 步骤 15 中的图像 1,1
    • Using a Phillips #1, remove the two 10.6 mm screws.
    • Gently pull back on on the cable to unplug it.
  16. HP Envy M6-1205DX Fan Replacement: 步骤 16 中的图像 1,1
    • Pull the fan out to remove it.
结论
7等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 5,689
