跳转到主内容
HP Envy 7640 Encoder Strip Replacement
你所需要的
  1. HP Envy 7640 Encoder Strip Replacement, Paper Roller: 步骤 1 中的图像 1,3 HP Envy 7640 Encoder Strip Replacement, Paper Roller: 步骤 1 中的图像 2,3 HP Envy 7640 Encoder Strip Replacement, Paper Roller: 步骤 1 中的图像 3,3
    • Open the printer by pushing upwards on the plastic tabs located on the sides of the printer.
    • Remove the opening assist from its purchase by pushing it toward the front of the printer with a nylon spudger.
    • Remove the spring-loaded clip attached to the top of the printer by pushing it off of the hook.
  2. HP Envy 7640 Encoder Strip Replacement: 步骤 2 中的图像 1,2 HP Envy 7640 Encoder Strip Replacement: 步骤 2 中的图像 2,2
    • Remove the last ten 12mm screws by placing the Torx 9 screwdriver in the screw slot and turning counterclockwise.
    • Remove the last two 12mm screws by placing the Torx 9 screwdriver in the screw slot and turning counterclockwise; the screen plate can now be separated from the printer by pushing out and to the right.
    • Take out the inner plastic frame (this piece is removeable after having removed the ten 12 mm screws outlined in the first bullet) by grasping the frame with both hands and carefully pulling the frame away from the printer body.
  3. HP Envy 7640 Encoder Strip Replacement: 步骤 3 中的图像 1,2 HP Envy 7640 Encoder Strip Replacement: 步骤 3 中的图像 2,2
    • Grasp the gray lever of the black plastic cover of the rollers and gently pull the lever up and to the right.
  4. HP Envy 7640 Encoder Strip Replacement: 步骤 4 中的图像 1,3 HP Envy 7640 Encoder Strip Replacement: 步骤 4 中的图像 2,3 HP Envy 7640 Encoder Strip Replacement: 步骤 4 中的图像 3,3
    • Press the lever outwards and away from the paper rollers with one hand.
    • Pull the paper rollers up and out of your HP printer with one hand while the other continues to depress the lever away from the paper rollers.
  5. HP Envy 7640 Encoder Strip Replacement, Encoder Strip: 步骤 5 中的图像 1,2 HP Envy 7640 Encoder Strip Replacement, Encoder Strip: 步骤 5 中的图像 2,2
    • Pull the encoder strip toward the slot it rests on to relieve the tension on the hook and slide the strip off the hook.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team S1-G2, Livingston Winter 2018 Cal Poly, Team S1-G2, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S1G2
3 名成员
创作了10篇指南
1指南评论
Thank you so much for this thorough explanation. You clearly understand how to repair HP printers. Perhaps I’m using an incorrect term for the very thin white plastic strip on the right hand side of the cartridge carrier. This strip is a fraction of the size of the strip on the left hand side of the carriage. This is the thin strip that is disconnected and which I would like to reconnect.
Diana Vick - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 36
总计 3,755
