当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
Unscrew the 10.5mm screw on the left of the desktop using your hand.
If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
You can now slide off the side panel of the desktop.
You should now have an opening on the side of your computer as shown in the second picture.
The location of the RAM is highlighted in red.
Undo the clips on each end of the chip as shown in the second picture.
Then you may carefully remove the RAM chips by pulling them out by their the ends.
Make sure you pull the chips out by the ends and not grabbing the entire thing. This may damage the chips.
Remember the slots that you take the RAM chips from. You must put the two replacement chips in the same slots.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
