跳转到主内容
加入维修社区 - 创建账户
HP Envy 700-030qe RAM Replacement
你所需要的
  1. HP Envy 700-030qe RAM Replacement, RAM: 步骤 1 中的图像 1,3 HP Envy 700-030qe RAM Replacement, RAM: 步骤 1 中的图像 2,3 HP Envy 700-030qe RAM Replacement, RAM: 步骤 1 中的图像 3,3
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe RAM Replacement: 步骤 2 中的图像 1,2 HP Envy 700-030qe RAM Replacement: 步骤 2 中的图像 2,2
    • You can now slide off the side panel of the desktop.
    • You should now have an opening on the side of your computer as shown in the second picture.
    • The location of the RAM is highlighted in red.
  3. HP Envy 700-030qe RAM Replacement: 步骤 3 中的图像 1,2 HP Envy 700-030qe RAM Replacement: 步骤 3 中的图像 2,2
    • Undo the clips on each end of the chip as shown in the second picture.
    • Then you may carefully remove the RAM chips by pulling them out by their the ends.
    • Make sure you pull the chips out by the ends and not grabbing the entire thing. This may damage the chips.
    • Remember the slots that you take the RAM chips from. You must put the two replacement chips in the same slots.
结论
Sam Wheeler
于10/01/15注册
228 声望
撰写一个指南
团队
Cal Poly, Team 5-9, Maness Fall 2015 Cal Poly, Team 5-9, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G9
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 41
总计 1,084
