当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
Unscrew the 10.5mm screw on the left of the desktop using your hand.
If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
Remove the side panel by sliding it towards the back of the desktop and pulling up on it as shown.
Remove the four 5mm screws holding the power supply in place with a T15 Torx screwdriver.
Undo the clasp which holds the power supply in place by pushing down on it.
Pull out the power supply up and towards you.
Unplug the power cable going to the CD drive by pulling straight.
Set aside the power supply on the left side of the computer.
Unplug the SATA interface power cable going to the hard drive by pulling straight up.
Unplug the power cable going to the mother board by pulling straight up.
Unplug the power cable going to the fan by pulling straight up.
取消:我没有完成这个指南。
2等其他人完成本指南。
与2其他贡献者
于10/01/15注册
321 声望
创作了2篇指南
徽章: 9
+ 6更多徽章
CPSU-MANESS-F15S5G9
4 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 52
总计 4,261
