跳转到主内容
HP Envy 700-030qe Power Supply Replacement
你所需要的
  1. HP Envy 700-030qe Power Supply Replacement, Power Supply: 步骤 1 中的图像 1,3 HP Envy 700-030qe Power Supply Replacement, Power Supply: 步骤 1 中的图像 2,3 HP Envy 700-030qe Power Supply Replacement, Power Supply: 步骤 1 中的图像 3,3
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe Power Supply Replacement: 步骤 2 中的图像 1,2 HP Envy 700-030qe Power Supply Replacement: 步骤 2 中的图像 2,2
    • Remove the side panel by sliding it towards the back of the desktop and pulling up on it as shown.
  3. HP Envy 700-030qe Power Supply Replacement: 步骤 3 中的图像 1,1
    • Remove the four 5mm screws holding the power supply in place with a T15 Torx screwdriver.
  4. HP Envy 700-030qe Power Supply Replacement: 步骤 4 中的图像 1,2 HP Envy 700-030qe Power Supply Replacement: 步骤 4 中的图像 2,2
    • Undo the clasp which holds the power supply in place by pushing down on it.
    • Pull out the power supply up and towards you.
  5. HP Envy 700-030qe Power Supply Replacement: 步骤 5 中的图像 1,1
    • Unplug the power cable going to the CD drive by pulling straight.
  6. HP Envy 700-030qe Power Supply Replacement: 步骤 6 中的图像 1,1
    • Set aside the power supply on the left side of the computer.
  7. HP Envy 700-030qe Power Supply Replacement: 步骤 7 中的图像 1,1
    • Unplug the SATA interface power cable going to the hard drive by pulling straight up.
  8. HP Envy 700-030qe Power Supply Replacement: 步骤 8 中的图像 1,1
    • Unplug the power cable going to the mother board by pulling straight up.
  9. HP Envy 700-030qe Power Supply Replacement: 步骤 9 中的图像 1,1
    • Unplug the power cable going to the fan by pulling straight up.
结论
2等其他人完成本指南。
Yoav Rosenberg
于10/01/15注册
321 声望
创作了2篇指南
团队
Cal Poly, Team 5-9, Maness Fall 2015 Cal Poly, Team 5-9, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G9
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 49
总计 4,255
