跳转到主内容
HP Envy 700-030qe CPU Fan Replacement
你所需要的
  1. HP Envy 700-030qe CPU Fan Replacement, CPU Fan: 步骤 1 中的图像 1,3 HP Envy 700-030qe CPU Fan Replacement, CPU Fan: 步骤 1 中的图像 2,3 HP Envy 700-030qe CPU Fan Replacement, CPU Fan: 步骤 1 中的图像 3,3
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe CPU Fan Replacement: 步骤 2 中的图像 1,2 HP Envy 700-030qe CPU Fan Replacement: 步骤 2 中的图像 2,2
    • Next, remove the side panel by sliding it towards the back of the desktop and pulling up, as shown.
  3. HP Envy 700-030qe CPU Fan Replacement: 步骤 3 中的图像 1,1
    • Remove the four 120mm Phillips #000 head, 5 mm screws holding the fan.
  4. HP Envy 700-030qe CPU Fan Replacement: 步骤 4 中的图像 1,1
    • Carefully pull up and disconnect the fan's power cable.
  5. HP Envy 700-030qe CPU Fan Replacement: 步骤 5 中的图像 1,1
    • Remove the fan by pulling up carefully.
结论
2等其他人完成本指南。
Jessica Resta
于10/01/15注册
235 声望
撰写一个指南
团队
Cal Poly, Team 5-9, Maness Fall 2015 Cal Poly, Team 5-9, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G9
4 名成员
创作了10篇指南
4条评论
Im looking to replace the fan in mine, what size would I look for, or even what model would be best?
AzyP Zero - 回复
Did you ever determine what fan to use ? I need to order one for my system.
Dennis - 回复
I bought the Philips #000 Screwdriver from iFixit as listed above. It is not even close to what is needed. That screwdriver is like a jewelers tiny Philips head. It needs a much bigger screwdriver.
Dennis - 回复
Fails to mention the most important part of the entire procedure. That would be to remove the old thermal paste from the top of the CPU with 91-99% isopropyl alcohol and re-apply new thermal paste. Short of doing this almost guarantees failure to maintain proper cooling.
Guy Martin - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 23
总计 3,339
