当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
Unscrew the 10.5mm screw on the left of the desktop using your hand.
If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
Reorient the device with the front pointing away from you.
Next, remove the SATA interface cable. It is directly next to the power cable on the CD drive.
Now stand your desktop up and remove the 3 clips on the right side of the front panel.
Then pull the front panel off, pulling from the side that the clips are on.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
