跳转到主内容
HP Envy 5660 LCD Replacement
你所需要的
  1. HP Envy 5660 LCD Replacement, LCD: 步骤 1 中的图像 1,1
    • Lift the scanner to open up the printer cartridge access area.
  2. HP Envy 5660 LCD Replacement: 步骤 2 中的图像 1,2 HP Envy 5660 LCD Replacement: 步骤 2 中的图像 2,2
    • Remove the two 12 mm screws with a T10 bit.
  3. HP Envy 5660 LCD Replacement: 步骤 3 中的图像 1,3 HP Envy 5660 LCD Replacement: 步骤 3 中的图像 2,3 HP Envy 5660 LCD Replacement: 步骤 3 中的图像 3,3
    • Use a metal spudger to pry open the front panel.
    • Work your way all the way around the front panel doing the same.
    • Gently flip the cover over, exposing the motherboard.
    • There will be loud popping sounds when the cover is being separated from the rest of the printer.
  4. HP Envy 5660 LCD Replacement: 步骤 4 中的图像 1,2 HP Envy 5660 LCD Replacement: 步骤 4 中的图像 2,2
    • Remove the four 4.5 mm screws from the motherboard with a T6 bit.
    • Gently remove the motherboard from the top of the LCD, but make sure the ribbon cables are still attached.
    • Beware damaging the white ribbon cable.
  5. HP Envy 5660 LCD Replacement: 步骤 5 中的图像 1,2 HP Envy 5660 LCD Replacement: 步骤 5 中的图像 2,2
    • Remove the four 5 mm screws with a T6 bit, allowing you to separate the LCD from the cover,
  6. HP Envy 5660 LCD Replacement: 步骤 6 中的图像 1,1
    • Place the metal spudger underneath the LCD and gently lift up to remove the LCD.
结论
另外一个人完成了本指南。
Ryan Steakley
于01/23/18注册
781 声望
创作了5篇指南
团队
Cal Poly, Team S1-G6, Livingston Winter 2018 Cal Poly, Team S1-G6, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S1G6
4 名成员
创作了10篇指南
2条评论
Great description but there is a part needed - the LCD. Is that part available? How do I get it?
Thanks,
PJE
pateckelberry - 回复
Ditto, I'm in the same position, did you ever find the part/LCD replacement screen?
Tessa Robles - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 1,102
