跳转到主内容
加入维修社区 - 创建账户
HP Envy 23-d060qd TouchSmart Speaker Replacement
你所需要的
    1. HP Envy 23-d060qd TouchSmart Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
      • Use your hands to unclip the plastic snaps on the back panel of the device.
      询问修复机器人
      添加评论
    2. HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 2 中的图像 1,1
      • Remove the three 11.5mm PH2 screws from the back panel.
      • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
      询问修复机器人
      添加评论
    3. HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 3 中的图像 1,1
      • Now, take the back panel off by pulling at it gently with your hands.
      询问修复机器人
      添加评论
    1. HP Envy 23-d060qd TouchSmart Speaker Replacement, Speakers: 步骤 4 中的图像 1,1
      • Remove the receiver for the keyboard and mouse with your hands.
      询问修复机器人
      添加评论
    2. HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 5 中的图像 1,2 HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 5 中的图像 2,2
      • Remove the four 17.5mm T15 screws from the speakers.
      • Remove the five 7.5mm T15 screws from the cover plate.
      • Remove the cover plate with your hands.
      询问修复机器人
      添加评论
    3. HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 6 中的图像 1,2 HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 6 中的图像 2,2
      • Disconnect the two speaker connections from the motherboard with your hands. Use your hands to gently pull the plastic piece at the ends of the wires.
      • Be gentle when disconnecting any wired connections. Pulling on the wires can damage them.
      询问修复机器人
      添加评论
    4. HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 7 中的图像 1,2 HP Envy 23-d060qd TouchSmart Speaker Replacement: 步骤 7 中的图像 2,2
      • Remove the speakers from the computer, and if needed, separate by disconnecting the wires between them.
      • Be gentle when separating wired connections. Pulling on the wires can damage them.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Zachary Dicks
于10/01/15注册
1,178 声望
创作了7篇指南
团队
Cal Poly, Team 5-10, Maness Fall 2015 Cal Poly, Team 5-10, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G10
4 名成员
创作了84篇指南
1指南评论
where to get the replacement speaker???????
Clovis Young - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 63
总计 2,084
